Cannot flatten this
Cannot flatten this
Frederick_Law
Mentor Mentor
Message 1 of 9
Cannot flatten this
Frederick_Law
Can't get this to flatten.
I'm "cheating" to show something (the hidden circle cut) on drawing and found out it can't flatten.
IV2023.4
@johnsonshiue
Replies (8)
Message 2 of 9
kacper.suchomski
Hi
Extrude 1 causes the problem. Does this cutout have to be inside?
I think this way the program loses the material thickness, which is necessary.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Message 3 of 9
Frederick_Law
It doesn't matter how "thick" the cut is, it'll fail as long as it doesn't cut through the part.
If that extrude cut through either side, it works.
Yes, I do want that circle inside.
And yes, normally it won't be modeled this way.
Message 4 of 9
kacper.suchomski
At the moment, the only solution I have found is model states with the hole disabled.
Kacper Suchomski
Message 5 of 9
johnsonshiue
Hi Frederick,
This is a limitation in Inventor Sheet Metal. The interior cutout introduces inconsistent thickness. As a result, the Flat Pattern rejects such body. There is a workaround, kind of hack, however. Here is what you want to do.
1) Reorder Flange1 above Extrusion1.
2) Move EOP below Flange1.
3) Unfold -> pick vertical face as the reference plane -> pick the bend.
4) Move EOP to the bottom.
5) Refold.
6) Create a new Model State with the Refold feature suppressed.
7) Document the new Model State as the Flat Pattern.
Many thanks!
Software Test Engineer
Message 6 of 9
Alexander_Chernikov
One more tip
If include hole in "Face2" or do it with "Hole" command the part will unfolded
(see attached file)
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 7 of 9
Frederick_Law
@johnsonshiue wrote:
Hi Frederick,
5) Refold.
Many thanks!
It will be ModelState with different size.  So can't use this trick.
Message 8 of 9
Frederick_Law
@Alexander_Chernikov wrote:
One more tip
(see attached file)
The goal is "hide" the "hole" inside the part.
As long as it cut through one face, it'll work.
As long as it's a "cavity" inside the part, it failed.
Message 9 of 9
Frederick_Law
Since this is a limitation, I'll try other way to get what I want.
