I can't seem to delete a frame item with frame generator.
Solved by Cadmanto. Go to Solution.
Has this part been altered in any way? Looks to me that the part is missing or moved and that is why FG is struggling to delete it.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
try promoting the part. then delete
Can you share the files ....
Promoted ? ? Come on, real issue - Frame Generator does not hold together very well.
Hello @dennisreeve I've found that some ways are more advantageous than others in organizing the skeleton sketch.
When you delete members do you RMB > Delete with Frame Generator?
If you can provide a simple example with Pack & Go as .zip so forum experts can comment on further that would be helpful.
Please select the Accept as Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
There has been one instance where this happened to me out of at least a thousand times of working fine. I use frame generator in tandem with iLogic daily with building curtain walls and punch window systems. Used correctly it works fine in my opinion.
I have the same issue. RMB "Delete with Frame Generator" gives this:
RMB "Promote Frame Generator Components" has no effect. Part still cannot be deleted.
However, RMB "Demote Frame Generator Components" creates the sub-assembly, which can then be deleted.
Another workaround that should not have to occur.
