Inventor Forum
Cannot break link to Simulation files. "Links" is grayed out
8 REPLIES 8
Message 1 of 9
DustinBTW
591 Views, 8 Replies
I have broken links in this assembly that I am trying to work in. They seem to be related to simulation that someone else has started on, but has sense then deleted the files and folders. But the link still remains.
I cannot select the "link" button on the tools tab either as its grayed out.
how else can I break these links?
2021-10-18 11_51_52-Autodesk Inventor Professional 2021.png2021-10-18 11_36_31-Autodesk Inventor Professional 2021.png2021-10-18 11_45_19-Autodesk Inventor Professional 2021.png
Intel Pentium 2 355mhz
128mb Ram
ATI 3d Rage Pro 8mb
10gb Harddrive
8 REPLIES 8
Message 2 of 9
SharkDesign
in reply to: DustinBTW
Can you go into the stress analysis environment and just delete the studies in there?
  Expert Elite
  Inventor Certified Professional
Message 3 of 9
JDMather
What do you see under Tools>Links?
Message 4 of 9
Gabriel_Watson
Message 5 of 9
DustinBTW
in reply to: JDMather
The one screenshot above shows that the "links" button is grayed out.
128mb Ram
ATI 3d Rage Pro 8mb
10gb Harddrive
Message 6 of 9
DustinBTW
in reply to: SharkDesign
No studies show up in the bowser when I enter the Stress analysis environment.
128mb Ram
ATI 3d Rage Pro 8mb
10gb Harddrive
Message 7 of 9
Gabriel_Watson
The (probable) solution I posted above is for when "links" is grayed out, but there are still underlying links. Yes, Autodesk is this gnarly sometimes...
Message 8 of 9
johnsonshiue
Hi! This is likely a corruption. I have seen files like this. Unfortunately, the links became orphaned. For assemblies, you might be able to demote the components to a new assembly. For parts, I am not aware of ways to remove those links.
Many thanks!
Software Test Engineer
Message 9 of 9
Gabriel_Watson
Another similar solution for NASTRAN FEA files I used in the past is this:
"- Nastran in-CAD > delete the FEA data from a model:
"Go to Default Settings -> Uncheck the box for "Save FE Modeling" data -> Click OK
Use "Save FE Modeling Data" option to retain or remove FEA data with the CAD model.
Right-click on "Mesh model" in the simulation tree and select "Delete Mesh".
Exit out of In-CAD
Save the model.
Close the model in the CAD software
Open the model in the CAD software
Go Back into In-CAD go to Default Settings -> reselect the box for Save FE Modeling data -> Click OK < >This is to re-enable the saving of the fea data, otherwise whenever a analysis is closed the data will always be removed.
Save the model and close the CAD software."
