Hi Forum
I'm wondering If I can add 2 different extrusion to the content center as the same feature.
Here is a example:
I have 1 extrusion going 10 mm deep and a inner extrusion going through.
I want to combine them so I can add them to the content center as one feature.
I did find another workaround:
1. add one feature (with the full sketch) to the Content Center
2.Place Feature in Part
3.Share the sketch of this feature and add another extrusion.
This isn't ideal since these 2 extrusions will always be used in combination of each other and it adds extra work for something that will be used a lot.
All help is welcome!
Solved by CCarreiras. Go to Solution.
Hi!
You can add both extrusions to your iFeature, even using the same sketch.
Basically, the Content center parts are iParts (several configurations, etc...)
The iFeatures in content Center are very basic.
You don't have to publish the iFeature in the content center.
You can create a more complex operation, and extract them to ifeature, save them in the Inventor Catalog (or other folder you want) and you may insert them when you need:
Tip: you can also create parametric features if you rename some key parameters.
