I'm having a similar (or possibly the same) issue, also on Inventor Professional 2025. I'll try to clarify:
The tutorial "Import a 2D drawing file in Inventor" has us import a .dwg file which is included in the tutorial's learning material download. This is placed onto the X-Y plane and the tutorial shows us how to change the origin point. Next, we begin a 2D sketch on that plane, and start the 'Project DWG Geometry' tool from the Sketch tab / Create panel on the ribbon.
The tutorial video then asks us to 'select all the segments that make up the geometry profile' and demonstrates this, highlighting each segment in turn.
Here's the problem:
On the video, as each segment is selected, those that were previously selected retain their highlight; however, this doesn't happen when we select them in the application. Hovering over a segment does indeed highlight it, but clicking it (with or without Ctrl held) does not appear to select it, since the highlight disappears when the mouse is moved away. Window-selecting the segments doesn't highlight them at all.
Troubleshooting attempted:
- The .dwg segments can be correctly selected when the 'Project DWG Geometry' tool is not active; however, starting the tool after selecting the required segments causes deselection.
- When the tool is active, choosing the 'Project Connected Geometry' (as opposed to the default 'Project Single Geometry') should allow selection of closed or open loops. This causes connected lines and arcs to be highlighted simultaneously; however, the highlight does not remain after clicking a loop.
- The help page for 'Project Geometry' says that "'Application Options > Sketch > Autoproject edges during curve creation' must be enabled." This option was already enabled.
After going through all of this, I have just clicked 'Sketch1' in the project browser and found that it has been correctly created, despite the lack of positive feedback from the selection highlighting.
C'est la vie!
