Can't run fwUI.dll
kbo
Can't run fwUI.dll
kbo
After installing Inventor 2020 on a brand new computer I kept getting the same error message.
Can't run :fwUI.dll
Tried to Repair, Reinstall - reinstall windows etc. but without success.
Finally ended up looking in to the Regional settings.
Removed the check mark from "Beta: Use Unicode UTF-8 for worldwide language support"
And that solved the problem 🙂   -  Damm you Microsoft.....Grrrrr
Replies (29)
johnsonshiue
Hi! This sounds like an install issue. Please make sure all critical Windows updates are installed and .Net 4.7 is installed. And, there is no running Inventor process in the background. Run Repair Install (Control Panel -> Programs and Features -> Autodesk Inventor 2020 -> right-click -> Uninstall/Change -> Repair Install).
If it still does not work, please send the Inventor install/setup log files (in %temp%) directly to me (johnson.shiue@autodesk.com).
Many thanks!
Software Test Engineer
Xun.Zhang
Aside from that, please check your Autodesk account or Autodesk Desktop App, there should be a licensing update just published recently.
Please install it and see if it works better.
Thanks!
Xun
kbo
Funny how the whole post isn't read 🙂 If you read the full post you'll see that the solution was included.
Call it installation issue yes, but more an error from Microsoft that they include a beta feature in a windows update.
And this beta feature prevent Inventor from beeing installed/working.
I am having the same issue.
All critical Windows updates are installed, .Net 4.7 is installed, licensing update has been performed.
Can you please suggest what else I can do to solve this issue? Thanks
The error message "Can't run fwUI.dll" appears during installation and anytime I try to launch the application
kbo
In Windows go to your settings <Time & Language>
<Region> and select <Additional date, time&regional settings>
Again the point <Region> and then in the tap "Administrative" click the button "Change system locale..."
In the dialog box there is a checkmark in
Remove that checkmark and you are properly good 🙂
It solved it for myself 🙂
Thanks for detailed instructions!
The described workaround worked for me as well.
Unfortunately it did not work for me. Any ideas someone?
Ran all the latest updates from widows 10 and now it is working.
ı followed the steps given in the solution for this problem but the error did not disappear ı just solved utxshared.dll file cannot be found the problem before having this error could it be the cause that the solution given for this problem does not solve the problem in my computer
johnsonshiue
Hi! Please share the exact behavior you are seeing. What is the error message? What release of Inventor are you on?
Many thanks!
I tried these suggestions but still get this .dll error. all updates have been installed. inventor pro 2020 on windows 10
when I try to launch my ap ı get ''Can't Load : FwUl.dll error ı uploaded a
screenshot of the error ı take ı tried to solve this problem within the
method given in the website of autodesk bu it didn't solve my problem ı
still get the same error. please help
johnsonshiue
Hi! Please share the screenshot of the error message you are seeing. Make sure you have all critical Windows updates installed. Have you tried Repair Install (Control Panel -> Programs and Features -> Autodesk Inventor 2020 -> right-click -> Uninstall/Change -> Repair Install)?
Many thanks!
Did anyone solved the problem with another solution than the one with fixing the box within windows timesettings?
I installed all updates both for windows and Inventor 2020 have the box unchecked but still having the same issue.
johnsonshiue
Hi! Your issue may be install related. First make sure .Net 4.7 is enabled. Go to "Turn Windows Features On or Off" and check .Net 4.7. After that, restart the machine. And, perform Inventor Repair Install (Control Panel -> Programs and Features -> Inventor 2020 -> right-click -> Uninstall/Change -> Repair Install.
If it still does not work, you may need to uninstall it using Autodesk Uninstall Tool (All Programs -> Autodesk -> Tools -> Uninstall Tool). Then reinstall Inventor 2020.
Many thanks!
I have the same issue. I've downloaded and installed Inventor 2020 on a Win10 PC. I have installed all Windows updates and Inventor updates but when I attempt to launch the program I get a pop-up dialog with the title, "C:\Program Files\Autodesk\Inventor 2020\Bin\Inventor.exe" and the message, "Can't Load: FwUI.dll."
I have followed the instructions you have given in this threat but it hasn't resolved the problem.
Can you look into this and suggest a solution please.
johnsonshiue
Hi! This is more likely your environment related. What Windows version are you on? Have you installed all critical Windows updates? Did you look at Reply#7 on this thread and turn off the option?
Many thanks!
My System is working again. I cleaned up all old Autodesk programs like Fusion and the Desktop Connector. Only reinstall Inventor didn't worked for me but as soon as everything was cleaned up and put back on Fusion and Inventor are working again.
EDIT: Timesettings like suggested before have been on the correct setup all the time
