Can't open solidworks 2018 file in Autodesk Inventor 2020
hugolopessilva
hugolopessilva
I downloaded a CAD file from Solidworks 2018, in format .sdlprt. I have Autodesk Inventor Professional 2020 in my laptop when when I try to open that file I get the following error message:
"This file is a newer version than Inventor can read. Install the latest updates for your version of Inventor and try the operation again."
How can I solve this problem?
thank you,
Best regards,
Hugo
TheCADWhisperer
Attach the *.sldprt file here for testing.
Gabriel_Watson
If you downloaded the part from a vendor website, most likely you also have other options such as STP, which is less restrictive to versioning. I would suggest importing an STP model if you can instead.
You can also install eDrawings as a free viewer to open your SLDPRT file and check File > Custom Properties to see which "Create Date" is on the file to give you an indication if it is a newer version than 2018 (never trust what a website tells you): https://www.edrawingsviewer.com/download-edrawings
hugolopessilva
Thank you for your swift reply. I really appreciate. I attach my .sldprt file.
Thank you,
Gabriel_Watson
Inventor 2020.4 imports it successfully. Are you able to check and update your PC to verify this hasn't been fixed in a newer version?
No custom properties to be seen, but the only real unusual aspect is when opening this in eDrawings I see a message saying the file displayed is out of date, liking to the page below if I click on "more":
http://help.solidworks.com/2020/English/eDrawings//t_Opening_Files.htm
TheCADWhisperer
The file is SolidWorks 2020.
