Some additional findings I have since posting this...
There were Coincident constraints applied to the angled top & bottom sketch lines to align those lines with the grounded sketch points at the top & bottom as there is an intentional offset from the projected vertical line. What's odd is that those Coincident constraints are not displaying when the line is selected or pressing F8 to reveal all constraints.
Removing these Coincident constraints from the iLogic code I'm using to place them (not shared due to NDA) should allow those angled lines to free-float up/or down and no longer be aligned to those points, yet they are still remaining aligned. Placing the horizontal offset dimension from the projected vertical line and the vertical sketch line now allows me to constrain as desired, but shouldn't.
For those that doubt the coding of the process, here's a snippet for this portion
oSKP1 = oSketch.SketchPoints.Add(oTG.CreatePoint2d(0, oHexRad * 2.54), False) 'top intersection point
oSKP2 = oSketch.SketchPoints.Add(oTG.CreatePoint2d(0, -oHexRad * 2.54), False) 'bottom intersection point
oGC.AddGround(oSKP1)
oGC.AddGround(oSKP2)
Dist = oMatThick * Sin(60 * PI / 180) * 2.54 'distance to create seam gap
'right side base sketch
If ThisSection = 1 Then
oLine(1) = oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(0.125, oHexRad * 2.54 - 1), oTG.CreatePoint2d(oBotRad * 2.54, BotFlat * 2.54 / 2))
oLine(2) = oSketch.SketchLines.AddByTwoPoints(oLine(1).EndSketchPoint, oTG.CreatePoint2d(oBotRad * 2.54, -BotFlat * 2.54 / 2))
oGC.AddVertical(oLine(2))
oLine(3) = oSketch.SketchLines.AddByTwoPoints(oLine(2).EndSketchPoint, oTG.CreatePoint2d(0.125, -oHexRad * 2.54 + 1))
oSKP = oSketch.SketchPoints.Add(oTG.CreatePoint2d(oBotRad * 2.54, 0), False)
oGC.AddMidpoint(oSKP, oLine(2))
oGC.AddHorizontalAlign(oSKP, oCP)
'moved horizontal dim offset here to get desired placement
oTmp = oDC.AddOffset(oVert, oLine(2), oTG.CreatePoint2d(oLine(2).Geometry.MidPoint.X / 2, 1), Flase, False)
oTmp.Parameter.Value = oBotRad * 2.54
oTmp = oDC.AddOffset(oVert, oLine(1).StartSketchPoint, oTG.CreatePoint2d(-5, oHexRad * 2.54 + 1), False, False)
If NoSections > 1 Then
oGC.AddVerticalAlign(oLine(3).EndSketchPoint, oLine(1).StartSketchPoint)
Else
oLine(3).EndSketchPoint.Merge(oSKP2)
oTmp = oDC.AddTwoLineAngle(oLine(1), oVert, oTG.CreatePoint2d(oLine(1).Geometry.MidPoint.X / 2, oLine(1).Geometry.MidPoint.Y), False)
oTmp.Parameter.Expression = "60 deg"
oTmp = oDC.AddTwoLineAngle(oLine(3), oVert, oTG.CreatePoint2d(oLine(3).Geometry.MidPoint.X / 2, oLine(3).Geometry.MidPoint.Y), False)
'Removing these constraints to resolve bug issue
'line alignment to points remains for some unknown reason
'oGC.AddCoincident(oLine(1), oSKP1)
'If NoSections > 1 Then oGC.AddCoincident(oLine(3), oSKP2)
'oTmp = oDC.AddOffset(oVert, oLine(2), oTG.CreatePoint2d(oLine(2).Geometry.MidPoint.X / 2, 1), Flase, False)
'oTmp.Parameter.Value = oBotRad * 2.54
Autodesk Inventor Certified Professional
