Can't open cgr-file in Inventor
Message 1 of 15
I'm having trouble opening cgr-files, made in CATIA, in Inventor.
What can be done?
The file attached is a picture of what Import options I have.
Alex
Replies (14)
Message 2 of 15
Marco.Takx
Try to turn of the Translation Report:
  • Embeded in Document
  • Save to Disk
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 3 of 15
Hi Marco,
Thank you for replying quickly, but unfortunately it didn't work.
Message 4 of 15
Marco.Takx
Can you post the CGR file so I can check within Inventor 2016 if I can open this file.
If so I can post the ipt or a step file here.
Marco Takx
Message 5 of 15
It's not possible to send cgr-files here, I discovered. But I can send you a step-file of a simple cube, which I can't open in Inventor either (after I've converted it to a cgr-file that is).
Kind Regards
Alex
Message 6 of 15
Marco.Takx
Witch version of Inventor are you using.
Are you up-to-date with your service packs/updates.
I have tested it within Inventor 2015 Professional SP2 Update 1 Inventor 2016 Professional RTM Update 2 without any problem.
Marco Takx
Message 7 of 15
I use the Factory Design Suite 2015, so Inventor 2015.
I don't know the status of the updates and/or service packs. The suite was however installed this summer.
I also discovered that I can't open the cgr-files in CATIA either.
Do we have he same settings on Import options?
Kind regards
Alex
Message 8 of 15
Marco.Takx
To check the service pack & Updates you can find them here.
Marco Takx
Message 9 of 15
Ok.
Release 2015 SP1 Update 3 - Date: Tue 02/10/2015.
That is what it says.
When you open the cgr-file, do you import the file or use the "open"-command?
Kind Regards
Alex
Message 10 of 15
Marco.Takx
I just open the STEP file and use these settings.
Marco Takx
Message 11 of 15
mcgyvr
Kind Regards
Alex
Simply zip the cgr file up and post it here..
uploading step files or any other format thats not cgr (zipped) is useless..
Also note that Inventor cannot open native cad files if the version is the same or newer than Inventor..
Example.. Inventor 2015 can open solidworks 2014 and older files but cannot open Solidworks 2015 files.
The easiest solution is to simply request step files instead of native cad files from any program.. Then you never have this problem
Message 12 of 15
It didn't work with those settings either.
What I'm after is to Publish Assets for a layout in AutoCAD architecture, and step-files are too large to handle for that purpose.
I also tried to publish a JT-file, but that wouldn't do the trick either. I attache a jpeg with the error message, maybe that is easier to solve.
Kind Regards
Alex
Message 13 of 15
Here's a zipped cgr-file.
Kind Regards
Alex
Message 14 of 15
mcgyvr
Kind Regards
Alex
Opens just fine on 2016..
Like I said above about the versions/years..
I suspect you are trying to open a crg file created in a version newer than your version of Inventor supports..
You can also check to make sure the CATIA V5 import translator is set to automatic loading.
tools..add-ins.. translators tab
Message 15 of 15
Hum, ok. We use CATIA V5-6R2012, which is where the file comes from, and Inventor 2015 for opening.
Do you have any ideas regarding publishing JT-files?
Kind Regards
Alex
