Can't edit constraint in Inventor Studio
matroosoft
Message 1 of 14
matroosoft
When I'm in Inventor Studio, trying to animate an assembly, I can edit the second but editting the first value is impossible. (the selected one on the screenshot. The part is which has to be animated is ungrounded, flexible and the constraint uses offset as resting position. (which I saw was recommendated in another topic)
The value simply doesn't change if I select it and type another value. Hope someone can help with this.
Replies (13)
Message 2 of 14
WHolzwarth
Can you set the new value in Assembly environment? IMO, then it's tranferred to Studio.
Walter Holzwarth
Message 3 of 14
matroosoft
I've tried it, but the offset value in assembly environment does not affect the first value in the studio environment.. If I, for example, set the offset to 50 in assembly environment it doesn't change the value in the studio environment (which is 90).
Message 4 of 14
WHolzwarth
Tested it right now with 2017. Worked ok with initial change in Assy environment.
If needed, I can place a video (not now, but some hours later)
Walter Holzwarth
Message 5 of 14
matroosoft
Hmm, I'm in 2017 as well and tried the same.. Even in a fresh assembly created just for testing this. If you want to make a video, it might be helpfull. I don't see what I'm doing wrong here! 😉
Message 6 of 14
WHolzwarth
Here's a link. (Screencasting is not my favorite playground) Smiley Wink
http://autode.sk/2no3PmP
But I got it later ..
Walter Holzwarth
Message 7 of 14
matroosoft
Thanks for the effort you put into this! I've followed the steps you did and realized you have a mate constrained with an offset, while I have a mate constraint with a min/max offset, so I changed that. That was the only difference.
After that, changing the offset off the constraint does indeed affect the first value in the studio environment, but if I change the second value (in the studio env.) then the first value changes to a random number. Seems pure magic to me.. Smiley FrustratedSmiley Indifferent
Message 8 of 14
WHolzwarth
Yes, Studio has some mysteries. I've been stumbling over them on my own.
Perhaps it's getting better, together with annual pricing ..
Walter Holzwarth
Message 9 of 14
matroosoft
Maybe. Smiley Happy Thanks for the help anyway! If I find a solution I will post it here.
Message 10 of 14
johnsonshiue
Hi The behavior does not sound right to me. The issue is more likely in the assembly constraints, not in Studio. Could you post the files here or send them to me directly ([email protected])?
Many thanks!
Software Test Engineer
Message 11 of 14
matroosoft
I've send you the files by e-mail. Looking forward to your response!
Message 12 of 14
Bill_Bogan1
Another approach would be to use positional representations and animate between the reps.
-bill
Bill Bogan
Principal Content Experience Designer
CXD
PDMS-DiD-Digital Manufacturing
Autodesk, Inc.
Message 13 of 14
WHolzwarth
Hmm. I've seen posreps behaving unreliable. If there are more than two for a constraint, uncontrolled jumps can appear.
Walter Holzwarth
Message 14 of 14
matroosoft
I had a talk with Johnson Shiue and after all I removed the limits of the concerned constraint. That didn't solve the problem in the assembly I was talking about but in a fresh assembly it did. I couldn't change the first value in the animation box either, but at least it wasn't a random number anymore (the value of the offset). So I consider this problem solved, at least for now. Thanks all for the replies!
