FLAT PATTERN
FLAT PATTERN
Message 1 of 12
FLAT PATTERN
PLEASE HELP ME !
I CAN NOT FLAT PATTERN THIS MY PRODUCT
THANKS
Replies (11)
Message 2 of 12
Rob67ert
Hi there,
For a better reading of your message I would suggest you turn of caps.
The part is correct for a FlatPattern. Two things, you have made is now of 4 independent plate's, there is no connection between them.
Second, a part like this is not able to make a FlatPattern, there are 2 bends across another.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 3 of 12
Dear Robert
I want them to be a plate
Same as this file
Message 4 of 12
Thomas_Savage
Do you mean like the file I have attached?
Thomas
Thomas Savage
Design Engineer
Message 5 of 12
Sorry, I can not read the file you send
  I am using Inventor  2015
Message 6 of 12
Rob67ert
You have to make another Corner Seam. (the cyan line)
And then a cut (extrusion 0.2mm width, red line)
Then it would work.
Robert
Message 7 of 12
Thomas_Savage
I tried to attach an .iges file. But wouldn't let me for some reason. Could you try a lofted flange and place a rip in it?
Thomas
Thomas Savage
Design Engineer
Message 8 of 12
Dear Robert,
I have repeated the Corner Seam many times and still can not
Can you help me ?
Many Thanks
Message 9 of 12
Thomas_Savage
Look at my print screens, is this what you mean?
Thomas
Thomas Savage
Design Engineer
Message 10 of 12
Dear Thomas,
Thanks you very much
Message 11 of 12
Rob67ert
For me with Inventor 2017 it was o problem te make.
You first have to make it as one metal.
I have it as a correct 2017 file, if you like i can send it.
Robert
Message 12 of 12
Thomas_Savage
You're welcome. Just copy what I did. Then you should be fine. If you get stuck just ask.
Thomas
Thomas Savage
Design Engineer
