I just migrated to INV 2023 (build 158)
In the assembly context, I am no longer able to drag a part around after placing the first constraint.
Typically, 3 constraints are required to lock down a part.
It will allow me to apply 2 more constrainst and it shifts, as it should, to the correct location.
But not being able to drag and move the part before fully constrained is a pain.
I did a re-built all, no effect.
There are no errors/warnings in the assembly.
This assembly was migrated from 2022
Any thoughts are appreciated.
Solved by johnsonshiue. Go to Solution.
Hi!
The software must work as you expect and describe.
Something is wrong or need update.
Can you share the files?
There are a few reasons this happens, but it is always because there is something causing conflict.
Hi! This is likely related to the presence of component pattern. It has been fixed on 2023.0.1 update. Please install 2023.0.1 update followed by 2023.2 update.
Many thanks!
