Inventor Forum
Can't drag part after 1 constraint
5 REPLIES 5
eucci
338 Views, 5 Replies
I just migrated to INV 2023 (build 158)
In the assembly context, I am no longer able to drag a part around after placing the first constraint.
Typically, 3 constraints are required to lock down a part.
It will allow me to apply 2 more constrainst and it shifts, as it should, to the correct location.
But not being able to drag and move the part before fully constrained is a pain.
I did a re-built all, no effect.
There are no errors/warnings in the assembly.
This assembly was migrated from 2022
Any thoughts are appreciated.
5 REPLIES 5
CCarreiras
in reply to: eucci
Hi!
The software must work as you expect and describe.
Something is wrong or need update.
  • Check if you have all updates installed (2023.2)
  • Check if you have the red cross active. If so, fix the errors.
CCarreiras
eucci
in reply to: CCarreiras
As mentioned, there are no errors in the file.
All updates have been applied.
BDCollett
in reply to: eucci
Can you share the files?
There are a few reasons this happens, but it is always because there is something causing conflict.
eucci
in reply to: BDCollett
Unfortunately, I cannot share the file
johnsonshiue
in reply to: eucci
Hi! This is likely related to the presence of component pattern. It has been fixed on 2023.0.1 update. Please install 2023.0.1 update followed by 2023.2 update.
Many thanks!
Software Test Engineer
