Inventor Forum
Can't create step file anymore
2 REPLIES 2
424 Views, 2 Replies
I used to be able to create a step file but can no longer. I now get the error message, "The procedure entry point
 ?IsNT6@UTxUtil@@SA_NXZ cound not be located in the dynamic link library utx.dll. Does this require a re-installation?
2 REPLIES 2
Restart the computer and Inventor, does it still happen?
If so you can try a repair install.
johnsonshiue
Hi! This sounds like install related issue. A shared component critical for Inventor to run is missing. Please go to Control Panel -> Programs and Features -> find the Inventor release you have -> right-click -> Uninstall/Change -> Repair Install. After that, does it work better? Many thanks!
Software Test Engineer
