Can't create custom content center library
m_scottW4DSR
m_scottW4DSR
New job, new Inventor installation.  It's probably a configuration issue.
I am unable to create a read/write content center library, getting the following error message:
Thanks in advance for the responses!
CCarreiras
Hi!
I'm noticing that MY LIBRARY is set to read only, it should be set to Read/Write.
Try to set MY LIBRARY as Read/Write first.
CCarreiras
m_scottW4DSR
Thanks for the response.
A lot of the functionality I am used to does not seem to be available to me.
I did not create My Library.  It seems that My Library was created at install as it has the same Created Date as the other Libraries.  I am unable to change its properties.
My true aim is to create a new library, which I am unable to do.
m_scottW4DSR
It seems that the problem is that the Libraries folder is ReadOnly and I need my IT guy to change the setting.
CCarreiras
MY LIBRARY is a default library that comes with the Inventor installation.
Usually, the library can come active or not, but always Read/Write, so i find that odd (to be  a read only library).
So, as you said,  the problem is probably your permissions to write in some folders..
CCarreiras
