Inventor Forum
Can't create a rip of a pipe
4 REPLIES 4
584 Views, 4 Replies
Hello everyone,
I can't make a rip and a flat pattern of a pipe. I have tried many different ways and I gave up.
Could you please help me?
Put cad file in attachments.
I use Inventor 2019.
Hello everyone,
4 REPLIES 4
Xun.Zhang
Xun.Zhang
Howdy  @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Please set the sheetmetal rule thickness = 6mm before execute the Rip command.
Please check out the fixed file for reference.
Hope it helps!
Xun
Hope it helps!
Xun
WHolzwarth
WHolzwarth
I've struggled with it, too. Ripping could be done only the conventional way.
With my flattening attempt I noticed, that sheetmetal standards were still not set.
Perhaps that's the cause for rip failure. I won't test it again.
2019 IPT attached
Later: Ok, same proposal from Xun a few seconds earlier
Walter Holzwarth
2019 IPT attached
Walter Holzwarth
in reply to: Xun.Zhang
It worked! Thank you very, very much  ! You made my day 🙂  I  thought I would lose my mind.
in reply to: WHolzwarth
Thank you. It was a basic, little thing as I thought 🙂
