Hello everyone,
I can't make a rip and a flat pattern of a pipe. I have tried many different ways and I gave up.
Could you please help me?
Put cad file in attachments.
I use Inventor 2019.
Hello everyone,
Solved by WHolzwarth. Go to Solution.
Solved by Xun.Zhang. Go to Solution.
Howdy @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Please set the sheetmetal rule thickness = 6mm before execute the Rip command.
Please check out the fixed file for reference.
Hope it helps!
Hope it helps!
I've struggled with it, too. Ripping could be done only the conventional way.
With my flattening attempt I noticed, that sheetmetal standards were still not set.
Perhaps that's the cause for rip failure. I won't test it again.
2019 IPT attached
Later: Ok, same proposal from Xun a few seconds earlier
Walter Holzwarth
2019 IPT attached
Walter Holzwarth
Thank you. It was a basic, little thing as I thought 🙂
