Can not change the name of frame generator members
niek.vanmierlo
Message 1 of 9
niek.vanmierlo
Dear all,
I've been using frame generator for quite sometime however, since today I can't change the name of frame members anymore when I want to save them. The column to do this is not visisble anymore. (see the attached picture).
Inventor 2020.
Thank you in advance.
Replies (8)
Message 2 of 9
CGBenner
@niek.vanmierlo
Hi, have you used the File Naming tool in Application Options?  If so, can you post a screen shot of those settings?  There might be something that is preventing you from changing the file name when the member is placed.
Chris Benner
Message 3 of 9
niek.vanmierlo
@CGBenner
Hello Chris,
Here are my file naming settings. I have never changed them.
Message 4 of 9
blandb
Click in the file name line, does the ellipsis button appear?
Autodesk Certified Professional
Message 5 of 9
niek.vanmierlo
@blandb
Hi, Nope they don't appear
Message 6 of 9
blandb
hmm, because mine don't appear until I click the file name cell.. I am on 2020.
Message 7 of 9
niek.vanmierlo
@blandb
Well mine doesn't appear at all..
Message 8 of 9
johnsonshiue
Hi Niek,
The behavior does not look right to me. Please make sure all critical Windows updates are installed and the latest Inventor updates are installed. If it still does not work, try using Inventor Reset Utility (All Programs -> Autodesk -> Inventor 20xx -> Tools) to reset all settings back to install default. Please note that the UI customization will be gone too.
Many thanks!
Software Test Engineer
Message 9 of 9
niek.vanmierlo
@johnsonshiue
Hi Johnson,
Resetting inventor fixed the issue, thank you for your help!
