Announcements
How to export into quad mesh?
travis.designer.vn
travis.designer.vn
Hi
I export inventor .iam into fbx and obj, they are triangle mesh. Are there option of exporting quad mesh?
mcgyvr
I believe Inventor only exports triangle mesh data..
You will likely need to use another program to convert to quad if needed.
cadman777
Rhino3D now has some quadmesh tools.
There are others too, but they're much more expensive.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
imajar
Not from Inventor.  If you are a subscriber, then you can use 3ds max to convert to a quad mesh.  (not alot of options though).  You could also look into meshlab or blender (both free) to convert to quad.
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
cadman777
I've used both Blender and MeshLab, and found Blender to be nearly impossible to learn. MeshLab is very limited but pretty good for basic stuff.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
