can it be made using sheet metal
Message 1 of 9
Hi,  Could this part be made using sheet metal tools. If yes how would i make?
Using 2015
Trent
Replies (8)
Message 2 of 9
stephenrottloff7259
Start with a flat pattern of the forked shape (in sheet metal mode of course).
Don't have the hemmed shapes in the flat pattern, they can be added later.
Use the fold command (not bend command) to form the 2 forked shapes down.
A sketch with a bend line would be required for the fold command.
Use the hem command to add the 2 hems to the "handle" of the forked shape.
Stephen R.
Message 3 of 9
JDMather
I am pretty sure I would not start with a flat pattern.
Message 4 of 9
mcgyvr
Any specific reason other than you hate the fold command? Smiley Wink
For such a simple part I really see no reason that fold couldn't be used.. Its just as easy to add the forks as regular flanges though too.
Message 5 of 9
I completely agree, I only start with the flat p[attern if there is no other way to model the part.
A finished dimensionally correct part is the end goal. As such there is a bunch of guessing at K-Factor etc when starting with a flat pattern.
I would use a contour flange, trim it for the forks etc and then add the hems. Flat pattern is created last and is size dependent on the part and K-Factor
Message 6 of 9
JDMather
Try it - and come up with the finished dimensions specified by the OP.
I had to do the attached part really fast to avoid being late to work - so check to make sure I got it right.
Message 7 of 9
mcgyvr
Yes I do agree that it can be more difficult to attempt to match furnished dimensions via the fold command.
Message 8 of 9
stephenrottloff7259
Yes I agree.  Saying to start with a flat pattern is confusing.
I should have said "Start with a sketch of the forked shape".
Thank you,
Stephen R.
Message 9 of 9
JDMather
Here is a slightly different technique that might be easier to edit to different sizes.
Does this solve your problem?
