Can i select more than one profile for sweep ????
tis07282015
Message 1 of 17
tis07282015
See attached file. I have sketch 9 (1.25'' dia) and sketch (.625'' dia)
What have I done wrong to complete sweep ? It allows me to select only one circle.
Sam
Replies (16)
Message 2 of 17
Cadmanto
A sweep will only allow you to do one profile.
A loft can do multiple profiles.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 17
tis07282015
I knew loft can do multiple profiles, how about path ? Can it be curved as I have in my file ? Solidwork does.
So my question is Loft or sweep can I do as in my file ?
Message 4 of 17
Cadmanto
Your part came in with no features.  As in my screen shot in my last posting, if that bent piece is what you are trying to sweep, doesn't look like it needs multiple profiles.
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 5 of 17
tis07282015
Forget about anything
In my file I have two circles(sketch 9 and sketch 10) and a path(sketch 13)
Can I do whatever you call loft or sweep ?
thanks
Message 6 of 17
jtylerbc
I can't see your part's features (including any sketches you have) either.  I assume it may be because you're on a newer version than I am.
Since I can't see your actual geometry, I may be heading the wrong direction a bit.  But it sounds like what you want may be a Loft with Center Line (which would be your path).
Could you post a screenshot of your sketches?  Since @Cadmanto and I don't seem to be able to see them in your model due to software version or something, that might help clarify what you are trying to do.
Message 7 of 17
JDMather
@tis07282015 wrote:
Solidwork does.
Can you Attach your SolidWorks file?
Your sketches are not fully constrained (this would be poor practice in SolidWorks or Inventor).
Your path is not constrained to the center of the circles (this would be poor practice in SolidWorks or Inventor).
Your path is not perpendicular to one of the profiles (I would expect that this does not return the results that you are after in SolidWorks).
Is this a class assignment?
Inventor error message tells you that the Profiles and Path are not connected.
Message 8 of 17
tis07282015
[cid:image001.png@01D4BA29.84DF01E0]
Message 9 of 17
tis07282015
I used to have Solidworks 10 years ago. I don't have it now.
Message 10 of 17
JDMather
I have used SolidWorks everyday (including this morning) for 17 years.
I always fully define my sketches.
It would make logical sense to constrain the beginning and end of path to the centers of the circles.
Message 11 of 17
tis07282015
Can you help me fully define
Sketch 9, sketch 10, sketch 13 ?. After that will it work ?
Message 12 of 17
Cadmanto
I am flying blind here seeing I don't have a visual of what you are describing, but back in the day when I created ergonomic type geometry, I did it by first creating a series of surfaces shaped and contoured the way I needed them, then trimmed surfaces to ultimately convert them through the thicken command to get the geometry.
Thinking you might have to do this.  So a couple of sweeps using the two different profiles, trim them to get what you are looking for.  It is a shot in the dark, but might be worth exploring.
Looking at your images above, you can have multiple guide curves in the loft.
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 13 of 17
JDMather
Edit the path sketch.
Drag the arc away from the circles.
Project Geometry (SWx Convert Entities) the center points of the two circles into your path sketch.
Add Coincident Constraints between the projected center points and the ends of the arc path.
(I already attached solution in previous response above.)
Message 14 of 17
tis07282015
Thank you
It worked. I just did not realize that when I created path it did not snap center point.
Thanks again
Message 15 of 17
JDMather
In Inventor you have to Project the Geometry.
There is a way to autoproject similar to SolidWorks, but I prefer to have more control.
But just like in SolidWorks - you can observe color change of sketch geometry when it is fully defined.
If you don't see color change, or thumbtack in browser (-) in SWx, then start dragging endpoints and observe.
This is perhaps the single most important diagnostic technique in both softwares.
Message 16 of 17
tis07282015
Great tip.
Thanks again
Message 17 of 17
johnsonshiue
Hi! This is fairly easy. Please take a look at attached part. Loft with Centerline rail is the way to go. The issue with the original part is in Sketch13. The arc does not intersect the big circle. Just project the center of the big circle. And, add a coincident constraint between the end point of the arc and the projected center. Then, the Loft should work.
I would be surprised if the exact same geometric condition works in SWX.
Many thanks!
Software Test Engineer
