Here is a very similar topic that I found for you. As I understood, you should be able to. There may be some things that you are limited to so I would dig a little bit deep. Here is the topic that I found on your issue. https://forums.autodesk.com/t5/fusion-support/will-snapdragon-x-elite-and-other-arm-based-cpus-on-wi...
Like I said, do a little bit of digging of your own. This was from last year, so some things have most likely changed. Let me know if there is anything else that I can help you with!
As always, "When you help others, you are not only helping them, but you are helping yourself learn better and more efficient ways of do things, so help others to help your mind!"
: Michael Wade
