As part of the device I am modelling I have two parallel rods
between which I will suspend a sail or parachute or what-yuh-muh-call-it
something like this. It will be made from linen or satin or something light (like a parachute).
Is it possible to model something like that in AI18 in such a way as it would behave like a satin parachute?
Solved by jhackney1972. Go to Solution.
Probably not. This type of modeling is better suited to Autodesk Maya.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Thanks. I thought not.
Perhaps learning Maya is more work that would be worthwhile in this case.
I'll just leave it up to the imagination.
