Can I import picture in Autodesk Inventor and extrude it?
Message 1 of 14
I have researching this for a while now and it is causing me a headache. I am new to Autodesk Inventor (3hrs into it), so please go easy on me. I have a company logo that I would like to make 3D. I am guessing I can't just import a picture and extrude it. But I would like to know at least how to import a picture so I can at least trace it in a sketch and then extrude it. How can I go about that?
Replies (13)
Message 2 of 14
JDMather
Start sketch.
Click the Image icon.
size as needed
exit sketch
Start new sketch and trace image.
Message 3 of 14
Cadmanto
Welcome to the forum.
See if this thread helps you.
http://forums.autodesk.com/t5/Autodesk-Inventor/Importing-Image-Quality/td-p/2614592
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 14
I have tried to import a pdf file into an Inventor  2014 idw file. The image looks good I save go out and go back in and image is a solid black rectangle
I have tried to import a png file into an Inventor 2014 idw file the image is so light I cannot read any of the text and it wont allow me to save.
Thank you for your help on this subjectKelly Roy
Brookhaven Nastional Laboratory
Message 5 of 14
I have the same isue as Kelly63.
After importing an immage into .idw and re-oppening the .idw the pasted immage is a solid black rectangle.
Can someone please help on this?
Message 6 of 14
TheCADWhisperer
@Anonymous
Can you attach the *.idw and the image file that you are attempting to use?
Message 7 of 14
What I did was use Adobe Illustrator to export an image into a .wmf (Windows Metafile), then imported that file into AutoCAD.  Then I saved the file as a .dwg in AutoCAD.  Then in Inventor create a new sketch, then go to Insert -> ACAD.
Then you extrude and blamo 3D image.
Hope this helps!
-Tom
Message 8 of 14
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Thanks for sharing the great information!
Message 9 of 14
what this works? gonna try it at once 😄
Message 10 of 14
Once in autocad, what steps need to be taken to convert the WMF to a DWG
Message 11 of 14
JDMather
You have posted this in the Autodesk Inventor forum.
The AutoCAD forum is >>over here<<.
Message 12 of 14
the solution to the problem in inventor lies in autocad, posted above in the 7th response
Message 13 of 14
MarceloKelahersEng
Community Visitor
Community Visitor
I failed to understand how the Autodesk cannot work in a simple easy way to add image in 2D. it is unbelievable.
Message 14 of 14
johnsonshiue
Hi! The issue with image is that the data is an a raster form. It requires conversion to geometry so that Inventor can understand. Such conversion isn't precise which can lead to other issues. AutoCAD and Fusion 360 have the ability to convert an image to sketch geometry. Please feel free to try them.
Many thanks!
Software Test Engineer
