Inventor Forum
Can flexible sub-assemblies be moved in DS?
3 REPLIES 3
WHolzwarth
642 Views, 3 Replies
Hi, some days ago kirash4 asked a question in this thread:
http://forums.autodesk.com/t5/inventor-general-discussion/how-to-edit-this-part-with-quot-base-quot-...
The part looked interesting, and therefore I've searched for further info and found this:
http://exiii.jp/hackberry--eng.html
I've looked into the HackBerry forum and found Inventor files for the system. I downloaded them from GitHub and took a deeper look. I've made some changes with parts and assemblies, mainly for structural improvements, and added several constraints.
Meanwhile I'm having a clean assy structure, and I'm trying to move the whole system in DS, time by time. I can do:
- Rotate the orange mount versus the basic arm (0s to 4s)
- Swivel the hand versus the orange mount (4s to 8s)
Next step would be moving three outer fingers (all same flexible sub-assy coupled with links) in DS. But here I'm stuck. I didn't find a way for doing this.
So let me ask: Can several flexible sub-assemblies be moved in DS?
Thanks for hints
Walter
Walter Holzwarth
3 REPLIES 3
JDMather
in reply to: WHolzwarth
You might need to right click and select Retain Degrees of Freedom in DS.
WHolzwarth
in reply to: JDMather
Thanks, Jeffrey.
Meanwhile I've tried with a simplified assy. I think, I can proceed. Zip with MP4 file is attached.
Walter
Walter Holzwarth
WHolzwarth
Now the full motion, zipped mp4 file.
Walter
Walter Holzwarth
