Inventor Forum
Can anyone see how to derive the inner and outer corner radii here?
1 REPLY 1
324 Views, 1 Reply
From here
http://www.tchweb.com/tchstore/product/500-101/c900/Lightweight-Medium-Recessed-Handle--Black.html
Obviously, we can project and inspect, but is there any way to deduce given the stated dimensions? I am using a lot of parts from these people, and I'm trying to see if they are sloppy or (more likely) I am consistently missing things.
From here
Tags (1)
1 REPLY 1
blair
blair
Nope, I'm missing it as well. They are also missing the vertical cut-out dimension as I can only find the horizonal measurement. I would assume you could get away with a rectangular cut-out with material thickness as a corner radius. I would guess a 73mm vertical cut-out.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Delta Tau Chi ΔΤΧ
