Inventor Forum
Can anyone explain to me why this part won't unfold?
4 REPLIES 4
563 Views, 4 Replies
Hi all.
I've got a part (several actually) which I've imported in IGS format, because it was initially designed in another piece of software.
9 out of 10 times I do this, I'm able to clean up the solid to the point where I can unfold with the sheet metal tools in Inventor.  Although I have quite a bit of these files to unfold, this workflow is fine for me.
Occasionally I have one (such as my example) which I just cannot figure out where the discrepancy is in this solid.
Does anyone have a surefire method of cleaning these types of files up that will eliminate this issue?
I can just make it over from scratch with the sheet metal tools, but for future reference, it would be nice to know if I can avoid that.
I appreciate any suggestions.
4 REPLIES 4
TheCADWhisperer
Does Manage>Rebuild All return any errors?
Are all cut edges perpendicular to the flat?
kelly.young
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
The method @TheCADWhisperer used by Delete Face > Thicken is by far the best way to accomplish imported solids to a Sheet Metal Flat Pattern
Another not as elegant way is to:
  • Use Feature Recognition to get the outside shape as a Sculpt (without the Fillets)
  • Project Geometry of the bottom face
  • Create the side Flanges (use measure on Sculpted Solid for any distances)
  • Extrude Cut To for the front angles
  • Extrude Join To the angled plane for the back angles
  • Extrude Cut To the little end notch
  • Unfold
  • Extrude Cut to remove the twisted sections
  • Refold
  • Create Flat Pattern
The flat patterns are fairly close, different ways to go about the same thing so thought I would show the scenic route.
Please select the Accept as Solution button if a post solves your issue or answers your question.
in reply to: TheCADWhisperer
Rebuild All did return an error: No edges found while making fillet feature.
Cut edges are not all perpendicular, but that alone usually doesn't seem to hold me up.  The only problem being that I need to be careful which edges I'm projecting when making a flat pattern!
Thank you, TheCADWhisperer, for the input!
in reply to: kelly.young
Delete Face > Thicken.
That did it.  Oh, and it was right in front of me the whole time!
I now feel schooled.
That is one little time saver I will use quite frequently.
Thank you @kelly.young and @TheCADWhisperer.
