Cable & Harness Ribbon Bend Radius
Message 1 of 32
Whenever I create ribbon cables, it always takes so long because I have a hard time getting the cable to represent in the rendered mode because it is saying the bend radius is too tight. Is there a way to turn off the "bend radius" requirement. I am not too concerned with the bend radius as it is only for visualization purposes.
kelly.young has edited your subject line for clarity: Ribbon Cables
Replies (31)
Message 21 of 32
Here is the cable in question
Message 22 of 32
mcgyvr
@Anonymous wrote:
Here is the cable assembly that I am having troubles with
yeah.. Autodesk just needs to do some work on C&H to improve its ability to sweep without so many issues..
Like I said in this or your other post.. Its currently a pain in the arse to route wires/cables and have them sweep properly without huge sweeping paths..
Their "sweep function" is just inferior really..
Message 23 of 32
JDMather
Looking at the assembly from the top view - shouldn't all of the points be in a straight line from that view?
Message 24 of 32
I suppose so
Kevin Pinks
Mechanical Draftsperson / Doc Control
Engineering
Industry Business
Schneider Electric
D +1-613-591-1943 x79387
F +1-613-591-1022
E [email protected]
415 Legget Drive, Suite 101
Kanata, Ontario K2K 3R1
Canada
[http://www.apcmedia.com/emailsignature/images/998-19615502_BrandBusinessBanners_620x80_5.jpg]<>
*Please consider the environment before printing this e-mail
[Blog]<> [FB] <> [Twitter] <> [Linked-In] <> [Youtube] <> [Instagram] <> [Google] <>
Message 25 of 32
I suppose so
Kevin Pinks
Engineering
Industry Business
Schneider Electric
F +1-613-591-1022
E [email protected]
Canada
Message 26 of 32
mcgyvr
Its just a great example to show just how inferior the program really is at doing these sweeps and how annoying it can be..
Even when greatly simplified and no sharp bends at all and less points it still fails to render..
Message 27 of 32
johnsonshiue
Hi Kevin, Many thanks for providing the example! It does look like the Ribbon cable path causes the sweep to fail in rendered mode. the path does not look too complicated. I will follow up with the project team and see what we can do here. Thanks again!
Software Test Engineer
Message 28 of 32
Any progress with this issue?
Message 29 of 32
Mark.Lancaster
@Anonymous
Sorry my reply is a little of topic and just a heads up.
I noticed a couple of postings of yours in this feed, it looked like you replied using your email system.  When you do this, it shares your email electronic signature which contains your personal information.   So make sure to come back to the forums and reply there.  Do not reply via your email.
In the end this type of information should not be posted here for security reasons.
If you don't mind that it is, disregard this message.  If you do have concerns, come back to the forum posting and use the report button next to your reply containing that personal information and notify the moderator to remove it.
Mark Lancaster
Message 30 of 32
johnsonshiue
Hi Kevin,
This is indeed a bug. It should work. But, I cannot say when it will be fixed. Please feel free to contact Autodesk Product Support and report a case.
Many thanks!
Message 31 of 32
mercerc
To make this easier it would most likely make a good enhancement request for the InventorIdeas station
What you can see in the returning files is I made some modification to the connector with the pins so I could add points to the ribbon cable and move them. This is a little time consuming and I'm not sure it would be a real-world length for the ribbon but give it a look.
Charlie M
Inventor Product Support Specialist
Message 32 of 32
mcgyvr
aka.. Don't hold your breath..
Its going to continue to be inferior for a LONG..LONG time..
We haven't seen any improvements to C&H in YEARS.
Seems there just aren't enough users for Autodesk to justify any time spent on it..
In fact I'm fairly sure ribbon cable enhancement was the last one and that was what ~10 years ago?
