Inventor Forum
Cable & Harness opening error
1 REPLY 1
286 Views, 1 Reply
Hai,
I got an error while opening the harness assy in inventor. error report is attached. Harnessing functions are not enabled to edit. can you please help.
Regards
Chenchu Kumar
1 REPLY 1
lesmfunk
I have had a similar error when I've tried to insert a T&P assembly into another assembly. I think Cable and Harness works the same way.
It should only be edited in the original upper assembly in which it was created unless you do not plan to use it in the original upper assembly anymore.
