Can C-profiles for easy fixing things on walls, be found in the standard Content Center libraries?
No but you can easily make your own and publish it to CC
Hi Johan. I have never seen these in the standard Content Center. I believe this is something that you would need to create as a custom library. You may even be able to download some base parts from somewhere on the internet, to save you some time in creating the base geometry... although this is a pretty simple profile.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Chris Benner
I'm yet to find any so far, all of the C Channels listed in the Structural Shapes section are open rather than forming a slot.
The closest I've found, but still a mile off was JIS G 3350D in the other section of Structural Shapes. It's just a bit big though.
Sounds like an ipart job.
Here's a way to speed it up if you have a data sheet.
You might find the iparts on cbliss's website as a useful starting place to build your own CC data.
http://www.cbliss.com/inventor/Parts/Structural/index.htm
There are lots of iparts and other standard components to use a starting point...
Steve Walton
Steve Walton
What about C_Bliss' web site?
Scroll down to "Framing Strut..."
@johan.degreef I'm not sure what proprietary system you use - in NZ it's usually unistrut and they provide CAD data. I only seem to be able to find it on the US site currently (imperial)
https://www.unistrut.us/resources/cad-files/3d
