BUG - Replace component can't be initiated from the Browser
andrewdroth
Advisor Advisor
andrewdroth
IV2020
When I select a component to be replaced in the browser I can't RMB continue until my cursor is in the design window.
When the cursor is in the Browser portion of the screen I only have a 'OK' option that doesn't do anything.
But if I select the component in the browser first, then initiate the command it works fine.
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
johnsonshiue
Hi Andrew,
I vaguely recall this bug. Does Ctrl+H work? Have you installed 2020.2 update followed by 2020.2.2 update? Make sure all critical Windows updates are installed.
Many thanks!
Software Test Engineer
