When I use the bubble command and attach the bubble to the part the bubble is twice to three times as big as it should be. How do I fix it? (it is only on one part that this happens on)
Are you talking about a "balloon" ?
Have you tried to edit the balloon style and see if some setting like "scale to text height" has been unchecked or something?
Hello, Thomas....
What do you mean by the bubble command? Can you post a picture? What version of the software are you using?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi Thomas_Rawie,
What data is displayed in the balloon? If it's a part number or description, check to see if there are extra spaces in the iProperties for that field. If it's an item number that displaying wrong, I'm not sure what would cause that, but you might provide a screen shot so others can see what you're seeing.
I hope this helps.
Curtis
RMB on balloon and select "edit balloon" is the information there correct with no override checked and the value information correct?
Did you try editing that balloon style too?
"seems" like its shape might be overridden to "Circular -2 entries" and the second entry is just blank.
and if you delete it and recreate it?
something must be causing that and I'd guess you could edit the style and figure it out fairly easily.. What happens when you start changing the style.. does it update properly.. What about overriding the shape,etc..
The guys that I work with and I have tried evreything possible and it dosen't change even after you change the shape. We think it has to do something with the overall assembly within the iam but can't figure out what.
