Inventor Forum
Bubble problem
14 REPLIES 14
Message 1 of 15
741 Views, 14 Replies
Bubble problem
When I use the bubble command and attach the bubble to the part the bubble is twice to three times as big as it should be.  How do I fix it?  (it is only on one part that this happens on)
Bubble problem
14 REPLIES 14
Message 2 of 15
mcgyvr
mcgyvr
Are you talking about a "balloon" ?
Have you tried to edit the balloon style and see if some setting like "scale to text height" has been unchecked or something?
Message 3 of 15
cbenner
cbenner
Message 4 of 15
Curtis_Waguespack
Curtis_Waguespack
Hi Thomas_Rawie,
What data is displayed in the balloon? If it's a part number or description, check to see if there are extra spaces in the iProperties for that field. If it's an item number that displaying wrong, I'm not sure what would cause that, but you might provide a screen shot so others can see what you're seeing.
I hope this helps.
Curtis
Hi Thomas_Rawie,
I hope this helps.
Curtis
Message 5 of 15
Here is a screen shot of my problem
Message 6 of 15
mrattray
mrattray
Looks to me like you added a carriage return after the item number.
Mike (not Matt) Rattray
Message 7 of 15
blair
in reply to: mrattray
blair
Check if there are any extra spaces in the field on the BOM for that part. Try doing a Re-number in the BOM as well
Delta Tau Chi ΔΤΧ
Delta Tau Chi ΔΤΧ
Message 8 of 15
in reply to: blair
Done and done.  Nothing
Message 9 of 15
No carriage return
No carriage return
Message 10 of 15
mcgyvr
mcgyvr
RMB on balloon and select "edit balloon" is the information there correct with no override checked and the value information correct?
Did you try editing that balloon style too?
"seems" like its shape might be overridden to "Circular -2 entries" and the second entry is just blank.
Message 11 of 15
in reply to: mcgyvr
Everything is correct no over ride and yes we tried editing the style
Message 12 of 15
mcgyvr
mcgyvr
and if you delete it and recreate it?
something must be causing that and I'd guess you could edit the style and figure it out fairly easily.. What happens when you start changing the style.. does it update properly.. What about overriding the shape,etc..
Message 13 of 15
in reply to: mcgyvr
The guys that I work with and I have tried evreything possible and it dosen't change even after you change the shape.  We think it has to do something with the overall assembly within the iam but can't figure out what.
Message 14 of 15
in reply to: mcgyvr
I don't know exactly what I did but I fixed it.
Message 15 of 15
blair
blair
I would look at the BOM in the IAM file. Look at the numbering for the item in question.
Delta Tau Chi ΔΤΧ
Delta Tau Chi ΔΤΧ
