brutal dimension behavior - ordinates
Accepted solutions (4)
jeremy_wasserstrass
Select all the dimensions and use the Arrange Dimensions selection in the right click menu. Then they all move at once and the leaders modify themselves.
Using Inventor 2026 on Windows 11
Ideas needing support: spur gear tooth profile, rack gears generator
SBix26
I would use Ordinate Dimension Set tool instead.  Adjusting the position of the first member of the set moves all the others, too.
Sam B
Inventor Professional 2017.3.1
Vault Workgroup 2017.0.1
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
mdavis22569
I agree, Ordinate Set
but if you don't.. here is the align
Mike Davis
mdavis22569
Ordinate Set Example:
Mike Davis
Thanks for the help everyone, I did not understand the difference between ordinate and ordinate sets since the original command seemed to do what I needed, also arrange dimensions wasn't something I ever saw as I don't think I had used right click during ordinate creation.
Finally, a friend dropped by and he said, if you move your cursor closer to the ordinate origin indicator, the behavior where you have to make extraordinarily long extension lines to get the dims to "pop out," is mitigated.
