Inventor Forum
Breakout and section participation
3 REPLIES 3
ronnybang
243 Views, 3 Replies
I have a problem with breakout, on 2D sheet.
Parts that has section participation set to None, will still be hidden if they are NOT touching the Breakout boundaries.
Anybody has a solution for this?
Best regards Ronny
3 REPLIES 3
CGBenner
in reply to: ronnybang
@ronnybang
Hello.  Can you share an image of what you are seeing, and what version of Inventor you are using?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
ronnybang
Where the red Arrow is, there should be angle profiles and fix anchors like where the blue Arrow is. They are all set to section participation "None".  I have played around with it, and found out that its all the parts NOT touching the boundaries for the Break out box, that is ignored by the section participation setting.
johnsonshiue
Hi! Please share the files here. I would like to understand the section view behavior better.
Many thanks!
Software Test Engineer
