Hi Guys
I have an incredibly annoying problem - and I think it's a bug from Autodesk.
If you have a BOM in an assembly that has custom iProperties specified as a column, then you can't sort by it. Also, the column must be at the very end, otherwise it always disappears from the sort selection.
I use Inventor 2023.2
Does anyone have any idea how to fix this????
thanks for your support
Solved by johnsonshiue. Go to Solution.
Hi! This is a known issue, reported as INVGEN-62175. It is a regression in Inventor 2023 from Inventor 2022. It has been resolved internally, targeting 2023.2.1 update (Jan 2023).
Many thanks!
Hi John
January is nearly over - is there a delay in release the upadte 2023.2.1?
thx for your update
cheers
Tom
Hi! There is indeed a bit delay due to the holiday season. The 2023.2.1 update is undergoing the final validation before release. I am very sorry for the delay.
Many thanks!
