BOM Item re-numbering Increments
adminVC7NR
adminVC7NR
I'm curious if there is a way to to have the re-numbering feature in the BOM show in increments of 0.1 opposed to strictly whole numbers. Screenshot attached for reference.
SharkDesign
No I don't believe you can do this.
  Inventor Certified Professional
GMSSC6R
Autodesk should note this as a feature request.
SharkDesign
The Inventor team will only note feature requests that are posted in the Ideas forum.
https://forums.autodesk.com/t5/inventor-forums/ct-p/inventor-en?page=1&tab=ideas
CCarreiras
Hi!
I believe is not possible, because the item number with a separator (. , ; - etc), is reserved for these situations in the image:
If this is what you mean to do, you have to go to the 3D model BOM and set to ALL LEVELS and select a delimiter:
CCarreiras
dan_inv09
Are you having difficulty renumbering within a sub-assembly?
