Problem with vault connected content center profile
bjorn.karlsson9HBA8
bjorn.karlsson9HBA8
Hello my name is Victor and i need help to reset a content center part
The problem was the naming of a profile had the wrong standard implemented and now when i have changed the name in the tables and rows the part naming and parameters seems to be missing
This part is U profiles that seems to be taken from a standard content center file from older vaults/content centers that we have had in our company. Now i need help either to reset this parameter issue or make a new one that is working
See pictures below for understanding the problem
The naming of the file becomes the same witch ever size and length you choose, i think its a parametring fault because i changed the information in the family tables and then the naming was not as in the code.
The naming of the part equals always profile name and 0,001 in length as in the picture
and i have tried to reset it to the original name but the parameters doesnt seem to add up anyways, i think its wrong with the row and column parametering but i cant figure out what! This is just a hunch See below
blandb
The family table > File name column is black, so it is stagnated. If there was a formula, then it would be blue.  You can right click on the column and go to column properties and see if there is an expression or not.
Autodesk Certified Professional
bjorn.karlsson9HBA8
Here is the file name properties like you explained
dave.cutting
When you're placing the part from the Content Centre, you have the as custom box ticked, so it will always ask you for a custom filename, rgardless of what is in the table. To use the C/C filename tick the as standard when placing the part.
As was mentioned previously, the filename file in your table doesn't seem to be concatenating the various fields as specified in the header. You could try deleting on of the cell values in the filename column and see if it goes blue. If it does, just delete all of the filename cells.
Dave Cutting
