Inventor Forum
Bolting the Run Parts
1 REPLY 1
justindelimo
262 Views, 1 Reply
Hello Everyone.
Can any one assist on how to place the bolting connection in the run components?
I make the pipe runs on pipe and tube with fange connections for presentation but after fininshing the runs and start to place the bolts on the flanges using Bolted connection component generator the runs lose all the constrains and  explode
1 REPLY 1
CGBenner
in reply to: justindelimo
@justindelimo
Hello.  Bolted connection is the correct way to do this, after you have built the piping with Tube & Pipe.  If your assemblies are coming apart, I believe this may be due to how the piping assemblies were constrained.  What you want to do is constrain your Master Pipe Run to the top level assembly using Flush constraints, origin plane to origin plane.  And then, activate the Master pipe run and constrain each of the individual pipe runs to the Master also using Flush constraints, origin plane to origin plane.  See my video demonstration.
This is a good practice for anyone using T&P because it "locks" you pipe runs in place so that they cannot move when working at the top level of your assembly.
Video link
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
