I have recently upgraded from Inventor 2022 to Inventor 2024 and have found that the bolted connection with points does not behave in the same way as it did before and now seems very buggy.
Typically in frame generator assemblies, if I needed to make bolt holes in my frames I would make a sketch with many points in an layout part and then use that sketch in a bolted connection. If I had rows of frames that had the same bolt pattern, I could use the same sketch in my bolted connections to make the holes I required. Also using the bolted connection with points would put holes in any member between the start and termination planes, even if there were multiple parts in multiply assemblies that were not in that path of the first point I selected.
Now in 2024 there are multiple issues that there were not before.
It is possible the functionality of bolted connection has changed between 2022 and 2024, please let me know if there is any way to improve my use of it so I can get back to using the way I did before.
Thanks!
Hi! The Bolted Conn behavior does not sound right to me. Unless the sketch is corrupted, all the points should be taken by Bolted Con. Please share the files you are working on or send it directly to johnson.shiue@autodesk. I would like to understand the issue better.
Many thanks!
