style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Dennis Jeffrey" <
href="mailto:djeffrey@teknigroup.com">djeffrey@teknigroup.com> wrote in
message
href="news:6115627@discussion.autodesk.com">news:6115627@discussion.autodesk.com...
Sorry... I thought you wanted a solution??? Why would I
waste my time on somthing you might not be able to open.
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009-SP1
PcCillin AV
HP zv5000 AMD64 2GB - Geforce Go 440, Driver: .8185
XP
Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
I come from the future and I have bad news. It's 2023 and such a feature has still not been implemented.
I currently use pretty much the strategy C which you have described but it's indeed not practical, as it need some 5 features (hole, pattern X, Pattern Y, Mirror X, Mirror Y), what could have been just a hole and a pattern.
A "perimeter pattern" would be excellent.
The issue with the sketch workflow from Josh is that newly added center points will not get a hole until you edit the hole feature.
Has anyone developed a better strategy for this?
Version?
Attach your file here.
You probably should have started a new discussion thread with a link back to this ancient thread for reference.
Version is 2022 and the file is not relevant, since the procedure is clearly described.
If you have a contribution to this discussion please add your thoughts here.
Some 5 years ago we got the sketch driven pattern, it can be used to collect all these holes in one pattern.
Create a sketch with center points - using sketch patterns to space center points as needed - as basis for the pattern.
Torbjørn
@br.sbrava wrote:
…file is not relevant…
I’ll move on.
