Best Practice for Constraining 6-axis Robots?
RNDinov8r
RNDinov8r
As a custom automation Design House, we utilize A LOT of 6-Axis and 4-Axis (SCARA) robots. Generally, the SCARA's don't give me too many problems in an assembly, however, I would say that 99% of the time, When I insert a 6-Axis Robot (Epson, Fanuc, or ABB supplied models which I then convert and apply joint constraints to), I will will get constraint errors when opening a higher level assembly. The Robots must be flexible as we have to be able to freely move them and put them in a significant number of positional reps. As a rule, I use an insert constraint on each joint, and then an Angle Constraint (Explicit Vector Reference Method). I usually suppress the angle constraint until I need to apply a Pos Rep in an upper level assembly.
JDMather
Attach assembly here that returns an error.
RNDinov8r
I was afraid of that response. I don' not currently have an assembly I can share that is giving me the issue...it is random, but frequent. As a rule, the model of the robot itself doesn't have the issue, it is when the robot assembly is inserted into another parent assembly that the issues arise. I will try to at least attach a model of the Robot assembly in a little while.
mcgyvr
Inventor still has issues with "flexibility".. Even at what one would expect would be fairly simplistic mechanisms/constraints.
https://forums.autodesk.com/t5/inventor-forum/flexibility-not-working-properly-in-inventor-bug-that-...
Good luck...
