I have been given access to Inventor to learn at work. My goal is to use linked parameters to make constructing crates and conforming them (and their interior braces & panels) to the size and relevant contours in a more automatic way. So far I have discovered 3 methods:
1) Linking files directly inside an assembly files between related parts files.
2) Using an linked empty parts file's parameters to govern the parameters of an assembly between related parts files.
3) Using a linked spreadsheet file to create parameters to govern the parameters of an assembly between related files.
Here is a simple example of what I am working with:
1/2" plywood with 1x4 trim piece.
The goal is to link the parameters of each trim piece so it changes size with the 1/2" plywood or abutting trim piece.
**DISCLAIMER: I am aware that another method of constructing the panel component is to make a series of solid bodies in a parts file. I am working on becoming familiar with that way also. I am exploring this method of making each part individually here.**
I would prefer to link parameters of the parts from the Assembly file. This article in Autodesk makes it seem simple to do:
However, the problem I have had with trying to do this is, the cells in the Fx parameters windows in the Assembly & Parts will only allow me to view the linked parameters I bring into them.
But I am unable to write an equation to command the labeled dimensions to conform to the other labeled dimensions.
Is there a way to link parameters across files in an Assembly file?
Do I have to link the Parts files first?
Is Inventor just not set up to allow linking parameters to be done this way?
If so, which one works better: using a) the Empty Parts File, or b) a Spreadsheet, to govern linked parameters for an Assembly file.
Thank you, Inventor wizards!
