Bending part angle to create parallel faces
spencernamcor_us
Message 1 of 16
spencernamcor_us
I am trying to bend a gusset so that one of it's side faces is flush to another gussets face.
Windows 11 Pro 64-bit
Inventor 2024
AutoCad 2024
Replies (15)
Message 2 of 16
mdavis22569
THey look parallel ... you may want to see if they are inline in the 3d assembly.
if they are both bent to the same angle then you know you need to look at the assembly
Mike Davis
Message 3 of 16
spencernamcor_us
Sorry. They are parallel. Wrong word. I am trying to get the outside faces flush, if that mkaes more sense.
Inventor 2024
AutoCad 2024
Message 4 of 16
mdavis22569
are they the same part
Mike Davis
Message 5 of 16
spencernamcor_us
They are not the same part.
Inventor 2024
AutoCad 2024
Message 6 of 16
mdavis22569
need to move the bend location back or forward on one ....
attach the assembly ....
Mike Davis
Message 7 of 16
JDMather
@Anonymous wrote:
I am trying to bend....
I doubt that I would use Bend Part.
Message 8 of 16
spencernamcor_us
What would you do?
Inventor 2024
AutoCad 2024
Message 9 of 16
JDMather
Attach your Bracket-front and Bracket-rear here and I will demonstrate what I would do.
Message 10 of 16
spencernamcor_us
OK.
Inventor 2024
AutoCad 2024
Message 11 of 16
JDMather
iProperties indicates that you are on r2015 Service Pack 0
The first thing I would do is install the latest Service Pack and Update for 2015.
Message 12 of 16
JDMather
Is there a logical reason that there are no dimensions on your sketches?
Were these sketches imported from AutoCAD?
Message 13 of 16
spencernamcor_us
Yes they were imported from autocad... unconstrained and undimensioned.
Inventor 2024
AutoCad 2024
Message 14 of 16
JDMather
Ah well, then my next step will be to fully constrain/dimension.
Does the Flat Patten size have to remain the same as provided in these two files?
Assuming yes, then I will figure out finished dimensions...
If no, then I will figure out finished dimensions...
...and model as Sheet Metal part.
Message 15 of 16
spencernamcor_us
Yes, I would prefer to not have to change the flat pattern dimensions.
Inventor 2024
AutoCad 2024
Message 16 of 16
spencernamcor_us
Any instruction as to what I should do next?
Inventor 2024
AutoCad 2024
