Inventor Forum
Bending a tube
7 REPLIES 7
Message 1 of 8
533 Views, 7 Replies
Bending a tube
Hello!
I am curious to find out if someone have time to help me out a little bit on the way to succes doing this part im trying to do atm.
Where would you start in a model like this, would u start of do a 2d sketch on the tube and then work your way, or you doing the model with a sweep interaction. Or u start of with the bend and work your way from there? I did manage to fix the circles kinda, but I think the bend part is the hard part?
So my question  if someone would like to give me a hint, or send me over a file so I can see how you suggest you would started this model. It is mm and not inches on the drawing.
Best regards a curious Oskar
7 REPLIES 7
Message 2 of 8
Mark.Lancaster
@Anonymous
Can you specify what version of INventor you are using so we can provide the correct file version to you...
Mark Lancaster
Message 3 of 8
IgorMir
Hi Oskar,
I can offer you this model for review. Please see the attached. IV2010 file format.
Igor.
Web: www.meqc.com.au
Message 4 of 8
in reply to: Mark.Lancaster
Im using inventor professional 2016
Message 5 of 8
NigelHay
in reply to: IgorMir
Nice model. I follow all of the steps except the 'stitch surface', why was that necessary?
Message 6 of 8
IgorMir
in reply to: NigelHay
Hi Nigel,
That step was necessary to convert Surfaces to Solid but can probably be avoided. I am sure - there are some other ways to model that part. I just did it in a short span of time - that's why there might be some extra steps in it.
Cheers,
Igor.
Message 7 of 8
PaulMunford
I would go for revolve and bend first. If that didn't work, then it would have to be a series of lofts..
Autodesk Marketing Manager D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Message 8 of 8
mcgyvr
Do you need it to "flex" in your models or will it always be in that exact same orientation/angle?
There was a neat "bellows" file posted on here a few years ago that would adapt as needed..
