Hello!
I am curious to find out if someone have time to help me out a little bit on the way to succes doing this part im trying to do atm.
Where would you start in a model like this, would u start of do a 2d sketch on the tube and then work your way, or you doing the model with a sweep interaction. Or u start of with the bend and work your way from there? I did manage to fix the circles kinda, but I think the bend part is the hard part?
So my question if someone would like to give me a hint, or send me over a file so I can see how you suggest you would started this model. It is mm and not inches on the drawing.
Best regards a curious Oskar
@Anonymous
Can you specify what version of INventor you are using so we can provide the correct file version to you...
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi Oskar,
I can offer you this model for review. Please see the attached. IV2010 file format.
Igor.
Hi Nigel,
That step was necessary to convert Surfaces to Solid but can probably be avoided. I am sure - there are some other ways to model that part. I just did it in a short span of time - that's why there might be some extra steps in it.
Cheers,
Igor.
@NigelHay wrote:Nice model. I follow all of the steps except the 'stitch surface', why was that necessary?
Do you need it to "flex" in your models or will it always be in that exact same orientation/angle?
There was a neat "bellows" file posted on here a few years ago that would adapt as needed..
