Inventor Forum
Bellmouth Flat Material
7 REPLIES 7
Message 1 of 8
468 Views, 7 Replies
Dear All,
I want to make bellmouth with inlet diameter inside 1400 and outlet diameter inside 700 with height 250.
if i use sheet metal there are use press process, but in here i plan using sppining process.
so its mean raw material in circle path with hole in center and without ripp part.
is there any other way can support these?
Best regards,
Yudika
Tags (1)
7 REPLIES 7
Message 2 of 8
Xun.Zhang
Hi Yudika,
I am not sure if you are asking a fabrication technique fesiable question or a CAD related one?
Could you help provide more information such as images, descriptions, etc to help me understand more?
Xun
Message 3 of 8
If you are wondering if Inventor will help you create the flat dimensions of the sheet metal the answer is no.
What you are doing is a metal stretching exercise and Inventor cannot calculate that. There is software that will do it but I do not know any details.
The small diameter should be the start point as it will not be stretched.
Message 4 of 8
Hi Mario,
I see, so in INV is cant use for strech condition, is it right.
I ll be use flatt pattenr for estimate matl weight for estimated quotation for refference.
Message 5 of 8
johnsonshiue
Hi! Inventor is a geometry modeler. Generally it does not consider material specific behavior. There is an exception to the rule though. In Sheet Metal environment, it does have workflows considering material stretch and contract in folding and unfolding operations. Without seeing an example, it is hard to tell if Sheet Metal can help.
Many thanks!
Software Test Engineer
Message 6 of 8
in reply to: johnsonshiue
Dear Johnson,
Thanks for you explanation,
Herewith i send 3D of part that i talked before.
Thanks and regards,
Yudika
Message 7 of 8
johnsonshiue
Hi Yudika,
Many thanks for sharing the part! This part looks like a punched sheet metal part. To manufacture the part, the sheet would undergo force-specific, material specific, and geometry-specific deformation. This is not something that Inventor as a geometric modeler can simulate yet.
If you are looking for a way to flatten the geometry, there is an alternative workflow you can consider. Basically, you will need to create a zero offset surface on one of the sides. Then export the surface as mesh. Download the free Mesh tool, Autodesk Mesh Mixer. Import the mesh to AMM. Use Unwrap command to flatten the mesh. Export the flattened mesh as a mesh file. Import it back to Inventor. You can use Fit Mesh surface command or recreate a flat surface based on the mesh. Here is a related thread.
https://forums.autodesk.com/t5/inventor-forum/unfold-complex-surface/m-p/7249578#M652238
Many thanks!
Message 8 of 8
Dear Johnson,
Thanks for your Reply in here,
 Due to i have busy in my job,
please Give me more time to review these method.
 I'll give you answer As Soon As Possible.
thanks,
Yudika
