Beginner tutorial for Inventor 2023
mikrows
Message 1 of 9
mikrows
I have no prior experience with inventor.
I downloaded Inventor 2023 trial, but cant find a 2023 tutorial that has the same screen layout as mine, even to getting started instructions on the Autodesk site were wrong for what I had on the screen.
I have burnt a whole day trying to get this working, to no avail, I cant even get the thing to stay on metric as default.
Whats more, I seem to be missing tabs.
Cane someone direct me to some useful help please.
Replies (8)
Message 2 of 9
JDMather
To set your default units go to Tools>Application Options and on the File tab select Configure Default Template...
@mikrows wrote:
What's more, I seem to be missing tabs.
Can you explain what tab are missing?
You can use Shift Win S and Ctrl V to copy and paste screen capture images in you Reply.
Message 3 of 9
CGBenner
@mikrows
Does your Ribbon look like the image below?  If so, click the arrow at the end, and check the box for Tutorials to activate that menu.
Chris Benner
Message 4 of 9
mcgyvr
In general tutorials for 2023 will be slim to none as its brand new.. However.. Very little is different from any of the tutorials for 2018+ though so you should be able to find everything with just a little digging at worst..
I'd recommend starting here...
https://www.youtube.com/watch?v=5PWqsRynm5I&t=0s
And yes Inventor has some built in tutorials which are fairly decent but I'd bet you learn a bit more going through the one I posted above. Plus you get to enjoy his witty humor and accent. 😉
Message 5 of 9
mikrows
Yes, I found that and turned on tutorials, but none of the tutorials show me how to actually start.
They either are a different screen or dont start from the beginning.
Message 6 of 9
mikrows
Thank you.
Message 7 of 9
mikrows
There is a pic of my opening screen in my post.
Message 8 of 9
mikrows
Yes, I started watching that one, but as you can see from my screen shot in my post, I dont have a 'get started' tab, but managed to get around it. Unfortunately, the files he uses are not available.
Message 9 of 9
JDMather
@mikrows wrote:
...but as you can see from my screen shot in my post, I dont have a 'get started' tab, but managed to get around it.
Click on this down arrow next to blank page - what do you see?
What is the name of the file?
Are you able to follow this video?
[video]
