I am looking for a way to save an imported stp file to vault, the issue with the file I received is it came in with 400 individual components within sub-assemblies. I am looking for a method to save the assembly with a specific name but then process all of the sub-assemblies and components and save them as the assembly name appended with a 001, 002, etc.. I would process it through the simplification tool and make it a simple part but this requires everything to be saved first as well, so doesn't save any time.
I am on Inventor 2024 with latest version and Vault Professional
Solved by swalton. Go to Solution.
@jmohanMDNM2
Hello and welcome to the forums!
Are you using Vault Basic or Professional with Inventor?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
@Gabriel_Watson Any ideas on this? Add to Vault, and then use Rename?
Chris Benner
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
@jmohanMDNM2 Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Do you use naming schemes from Vault?
Try this workflow
Alternate method
Or maybe iLogic...
Take a look at this script and see if it can be modified to match your needs. Run it once you know the top-level filename.
Once everything is named correctly, check it into Vault. You may need to be logged out of Vault while the script runs.
Steve Walton
Chris Benner
