Inventor Forum
Subassembly won't move when added to the main-assembly, even though marked as flexible.
5 REPLIES 5
richard_bankov
366 Views, 5 Replies
richard_bankov
Observer
Observer
Hello, I am modeling parallel manipulator and links are translational joint with universal joints on both sides, but when I add them to the main assembly and try to connect other components with them I can not select one part of the assembly only whole sub-assembly.
5 REPLIES 5
CGBenner
in reply to: richard_bankov
CGBenner
@richard_bankov
Hello, and welcome to the forum.  To make it easier for others to help you, can you provide some more information?  What version of Inventor are you using?  Can you share some screen shots of what you are working on, and where the problem is?  Thank you and good luck.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
@richard_bankov
Chris Benner
mluterman
mluterman
Two things from your description:
1. Right-click in window and switch to "Part Priority" to select individual parts.
2. In your flexible assembly (which is a subassembly of your main assembly), you must leave at least one part unconstrained so it has the freedom to move in the upper assembly into which it is placed. Once you place it in your main/upper assembly, you can constrain the moving part to something in that upper assembly.
johnsonshiue
Hi Richard,
Please make sure all critical Windows updates are installed and the graphics driver is updated. If you are on 2024, please install 2024.3 update.
If there are preexisting failed constraints, either fix it or delete it. Another possibility is the subassembly contains adaptive parts. Adaptive parts usually have reduced degree of freedom.
If nothing above helps, please share the files in zip here. The forum experts can help take a further look to understand the behavior better.
Many thanks!
Software Test Engineer
Hi Richard,
Many thanks!
CGBenner
CGBenner
@richard_bankov Hello, do you still need help with this question?
Chris Benner
Chris Benner
richard_bankov
in reply to: CGBenner
richard_bankov
Observer
Observer
Hello, Thank you for help. I am good now. Problem was in the incorrect length of translational joints.
